주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Change the thermal paste
How to change the thermal paste on the processor of Legion laptop
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
If you are experiencing high temperatures or your Legion laptop is overheating, it may be time to change the thermal paste on the processor. Here are the steps to follow:
  1. Turn off the laptop and unplug it from the power source.
  2. Remove the back cover of the laptop. This will require unscrewing several screws on the back cover.
  3. Locate the CPU and GPU on the motherboard. The processor will be covered by a heatsink.
  4. Remove the heatsink by unscrewing the screws that hold it in place. Carefully remove the heatsink, being sure not to damage the processor.
  5. Clean the old thermal paste from the processor and heatsink using a clean cloth or cotton swab and isopropyl alcohol.
  6. Apply a small amount of new thermal paste to the center of the processor. Be sure to use only high-quality thermal paste.
  7. Replace the heatsink on the processor and screw it back in place.
  8. Reattach the back cover of the laptop and screw it in place.
  9. Turn on the laptop and check the temperature of the processor using a monitoring software. You should notice a decrease in temperature after changing the thermal paste.
Changing the thermal paste on the processor of your Legion laptop can help improve its performance and prevent overheating. However, if you are not confident in your ability to do this, it is best to seek professional help.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
hi @monkey86988
Here's the hardware maintenance manual for the laptop.
Go to p.63 to view the procedure to remove the thermal module. This will allow you to access the CPU and the GPU so that the old thermal paste can be removed and a fresh coating applied.
Here's the ifixit 서멀 페이스트 도포 방법 guide that will also help.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
monkey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 9
지난 7일: 30
지난 30일: 121
전체 시간: 7,343
