주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hiretech HTF-2 샌더는 Hiretech에서 출시한 오비탈 바닥 및 데크 샌더입니다. 2014년에 출시되었습니다. 모델 번호: 01407 및 01181.
Unit wont cut off
The unit wont cut off with the switch. The only way to get it to cut off is to unplug it. We have taken the switch off and everything appears to be in good shape and none of the wires appear to be loose.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @kimberly87496,
Check the switch using a DMM's (digital multimeter) Ohmmeter function - disconnect the power to the device first - to ensure that it is electrically working OK and not that it just appears to be mechanically working OK i.e. contacts closed when switch operated 0.00 Ohms on meter, contacts open when switch released OL or infinity reading on meter.
The switch contacts could be welded shut for example, so even though the switch seems to be operating and releasing, the switch contacts may not be.
If the switch is faulty here's the parts list.
Search online using the switch part number appropriate to your location i.e. household power supply voltage value, to find suppliers that suit you best. Insert PSTK in front of the part number in the search term.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Kimberly 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 9
지난 7일: 12
지난 30일: 27
전체 시간: 482
