주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G533 무선 게이밍 헤드셋의 수리 및 분해 정보입니다. G533은 모델 번호 A-00072를 통해 식별할 수 있습니다. 2017년 1월에 출시되었습니다.
Mic randomly stopped working
I can hear the beep which indicates my mic is being turned on when the mic is flipped up to mute and down to unmute. Although i hear the headset is registering the mic being used for some reason, it just stopped working.
does anyone have experience replacing the mic on one of these? if so please share your experience and point me in the right direction for replacement parts.
thank you in advance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
I had the same issue with 2 Headsets I bought used. One had this from the moment I bought it, the 2nd worked fine for about 1 year.
I guess the problem is a cable failure in the lever mechanism
의
댓글 달기
답변 1개
가장 유용한 답변
Hi HawgDawg,
I was going to answer, but ran across someone else with a similar problem and the first comment on that question was pretty much exactly what I was going to say, so I'll just link to that question and let you read it for yourself.
Mic doesn’t work - Logitech G533 - iFixit
See the comment by F Dryer (@notbroken ) for a very good explanation of exactly what I was thinking.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks for the reply Jerry
I can't seem to find the comment you're referring to, the thread you linked was helpful though.
의
댓글 달기
답변을 추가하세요
HawgDawg 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 53
전체 시간: 3,649
