주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
XPS 13 9360은 2016년에 출시된 13인치 노트북으로, 7세대 Intel 프로세서가 탑재되었습니다. 2017년에는 8세대 프로세서로 업데이트되었습니다.
Battery Replacement problem for Dell 9360
I recently replaced the battery for my Dell 9360 using the Dell XPS 13 9360 Replacement Battery kit from iFixit, and it seemed to work fine for a few days, but now my battery doesn't seem to be charging properly. I followed the battery replacement instructions meticulously (Dell XPS 13 9360 배터리 교체). However, now my battery often gets stuck charging at odd numbers like 32% for hours on end (similar to this post: New 97w Battery Replacement - Not charging past 47%) and will last < 2 hours without being plugged in. Somewhat relatedly, whenever it is plugged in, the fan is usually whirring a lot trying to keep cool.
I made a battery report like the post above's answer by @jayeff suggested. According to it, I have a 60,002 mWh design capacity, and a 45,288 mWh full charge capacity. Are these two numbers sufficiently close to each other? Do I have a bad battery? Is this a calibration problem? Did I just buy the wrong one??
Any help is appreciated!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @matthewwhi66266
It looks like a bad battery.
Looking at the figures you posted it is only charging to 75% which is poor considering it is supposed to be new.
Contact ifixit about the problem and get a replacement.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
댓글 달기
답변을 추가하세요
Matthew Whitley 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 21
전체 시간: 556
