주요 콘텐츠로 건너뛰기
The Xterra was introduced in North America in the 2000 model year (1999 calendar year) and marketed using the tagline Everything you need, nothing you don't.
12 질문 전체 보기
car stalls after running for 30 min.
I've replaced the fuel pump, fuel filter, and fuel pump relay. the only codes I get are for the cat. so I staight piped them both. still stalls after running for 30 min. starts fine after it cools down.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
@kijdfp08uw5vqvf what codes did you get?
PO463, PO420,and PO430
댓글 달기
답변 1개
First off after changing all those parts did you reset the ECM? If not the auto still thinks the sensors are bad. Secondly it sound s like you original problem is electrical. Something is getting warm and going into default. Things like the coil and resistors for the ignition will not show on a code reader or self diagnostic reading.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
mr.skeleton1969 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 84
