주요 콘텐츠로 건너뛰기
Why my phone vibration is not working
My phone vabrtion is not working correctly
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 4개
선택된 해법
Hi well this video might be helpful for you: https://www.youtube.com/watch?v=W0-_BKzz...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
가장 유용한 답변
Why Samsung Galaxy M32 Vibration is not working If you are experiencing issues with the vibration not working on your Samsung Galaxy M32, there could be a number of causes. Here are some possible reasons why your phone's vibration is not working:
  1. Vibration is turned off: The first thing to check is whether the vibration is turned on in your phone's settings. To do this, go to Settings > Sounds and Vibration > Vibration Intensity and make sure the switch is turned on.
  2. Phone is in silent mode: If your phone is in silent mode, it will not vibrate. Check the volume settings on your phone to make sure it is not in silent mode.
  3. Vibration motor is damaged: If the vibration motor in your phone is damaged or malfunctioning, it may need to be repaired or replaced.
  4. Software issue: Occasionally, a software issue can cause problems with the vibration on your phone. Try restarting your phone or performing a factory reset to see if this resolves the issue.
Source Finddee
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Why my phone not vibrating
이 답변이 도움이 되었나요?
점수 2
댓글 달기
#0# dial this number and then select vibration in the menu
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
mintesnot ayele 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 34
지난 30일: 150
전체 시간: 17,566
