주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년에 출시된, 제빙기나 문을 통한 디스펜서가 없는 자동 제상 방식의 GE Refrigerator GFE26JGM**** 냉장고에 대한 수리 및 추가 정보입니다. 이 페이지는 GFE26JGM**** 모델 번호와 일치하는 모델에 대한 정보를 다룹니다.
Wiring connector assembly help
Removed the doors, while disconnecting the harness, the connector came off. The color of the wires don't match. We need help matching the wires back up
Black/yellow, white, 2 white/blue
Black yellow, white, red/white, gray/white
Update (05/05/23)
이미지
이미지
Update (05/05/23)
  • trying again
이미지
이미지
Update (05/05/23)
GFE26JGMWFBB is the model
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
can you add photos
의 공유
@dougwilds i can't see them doug it just says image
의 공유
@dougwilds pictures can only be added to Question or Answers , not comments. It's fixed :-)
What make and model is this?
의 공유
댓글 달기
답변 1개
가장 유용한 답변
Hi @dougwilds
I can't find the mini manual (GE part #31-1000533) for a GFE26JGMWFBB but there are two models which are very close, i.e. GFE26JGMAFBB & GFE26JGMNFBB.
Unfortunately they have different mini manual part numbers not only from your model but from each other as well. Maybe there are slight variations in the wiring due to them having different features perhaps
At least they show the connections and colours of all of the wires used
GFE26JGMAFBB (31-1000396)
GFE26JGMNFBB (31-1000474)
Using an Ohmmeter, you may have to identify the wires by colour back to the main board connector pins, by looking at either of the manuals to see if one is appropropriate.
Hopefully one will be and then once you know where they connect to on the mainboard, use that manual to see where they go to and what colour wire they connect to or end up as.
Hopefully this is of some help.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Doug Wilds 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 33
전체 시간: 645
