주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nexus S는 Google과 공동-개발한 스마트폰이며 Samsung은 Android 2.3 "Gingerbread" 운영 체제를 사용하는 최초의 스마트폰이었습니다.
How to change faulty USB port
I have an issue which relates to the micro usb port on my Nexus S not working.
How hard or easy is it to change the port ?
I've looked at the disassembly here on the website and did not manage to see clearly how the USB port was connected to the board.
Best regards,
Daniel
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
I also have a problem with my USB port which I think might be solved by replacing it. Phone works as normal but I'm unable to charge or connect it to a computer via its USB port.
Just wondering if the original poster or anyone else tried replacing the USB port and how easy/hard it was?
의
댓글 달기
답변 1개
선택된 해법
Daniel Manolache, it is soldered onto the board and will require soldering to replace. The part itself is inexpensive so if you are hesitant to do it yourself, you might want to try a local TV repair shop. Parts are available at places like this
이 답변이 도움이 되었나요?
점수 4
댓글 달기
답변을 추가하세요
Daniel Manolache 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 7,349
