주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
동명의 사회적 기업이 만든 4세대 Fairphone. 2021년 10월 출시됨.
Phone call or receive problems!
Everytime, I make a phone call or received a phone call. There other side how call me is not able to hear my voices. Help to fix FairPhone 4. Do you think is the speaker part is the problem?
Update (05/13/23)
이미지
Which part?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
https://www.google.com/amp/s/amp.theguar...
Which part?
I try to put the image is not working well. So, put a link.
의
댓글 달기
답변 2개
선택된 해법
No you have a problem in your Microphone, you should replace it.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
The speaker and microphone are the same part or component?
의
댓글 달기
가장 유용한 답변
Hi @erickonix,
Can you be heard OK when using the phone in loudspeaker mode when on a call?
Is the phone in a protective case at all? If so remove from the case and check if it now works OK.
Try using a vacuum cleaner to clear the voice inlet hole located on the bottom edge of the phone in case it is blocked with lint etc, and check.
If still no good it may be the microphone in the phone.
이 답변이 도움이 되었나요?
점수 3
댓글 15개:
Even with or without the phone case still same problem. Where is located the microphone?
의
@erickonix
Did you try clearing the voice inlet hole using a vacuum cleaner, you didn't say?
의
Can you show me as pictures where is located?
의
@erickonix
Can't find any pictures but there are two small holes on the bottom edge of the phone for the microphone.
Do not stick a pin in them to see if they're clear as you may damage it
There's also a small hole at the top for another microphone which is used for loudspeaker calls
의
In bottom part of FairPhone 4. In the center bottom is USB type C. At the right side of USB type C have 3 holes. At the left side is have small hole. So, which part is the microphone?
의
댓글 10개 더보기
댓글 달기
답변을 추가하세요
erickonix 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 12
지난 7일: 55
지난 30일: 88
전체 시간: 2,100
