주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Toyota Camry XV20 시리즈는 Toyota의 6세대 Camry 세단입니다.
Why is my car overheating
I have a 1998 Toyota camary I replaced the radiator and the thermostat I’m currently working on the radiator fan,the fan works but the relay is the issue I got a new relay but it still doesn’t turn the fan on automatically. I manually got the fans to operate by taking one of the electrical connectors to see if the car would still overheat and it does. So I total I changed my radiator my thermostat and my Fans work. what could be another problem. I’m currently bleeding my radiator so I can put some new antifreeze in it to see if it would work
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
@dae70295 your check fan switch (ECT Switch) on the right side lower tank of the radiator. It is possible that this is not turning your fan on. Since you already replaced the relay, you should have power to the switch. Check there.
This part Cooling of the SM should help you with your diagnostics.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thank you I will check that now hopefully I find the solution to my problem
의
댓글 달기
답변을 추가하세요
Dae 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 15
전체 시간: 477
