주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Laptop 14-dk1022wm은 작고 가성비가 뛰어나 학생과 일반 직장인이 학교, 업무, 개인용으로 널리 사용하는 기기입니다.
My laptop battery is getting down.Any solution?
My laptop battery is getting decreasing fast.I need solution about it. Kindly comment on this information.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
Hi @sohammaity
Create a battery report to find out the charge status of the battery.
When you have the report, compare the Design Capacity value versus the Full Charge Capacity value and check what percentage the Full Charge value is of the Design Capacity value. If it is <40% you should consider replacing the battery.
If you determine that the battery needs replacing, here's the maintenance and service guide, taken from this support webpage for the laptop model.
Go to p.35 to view the procedure to remove/replace the battery.
At the top of p.35 you will find the part numbers for the 2 compatible batteries that may be used in the laptop. Search online using the part number only, to find suppliers that suit you best.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I personally do not have this issue, but I have never heard of the battery report before.
I created a battery report and wow, that's awesome. Thank you for that information!
의
댓글 달기
To replace the battery with a new battery is the fast way.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Well I will suggest you to replace your old battery with the new battery this the best solution to issue which your facing.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Soham Maity 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 13
전체 시간: 761
