주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
15.4인치 디스플레이를 탑재한 Dell의 노트북 PC입니다. Inspiron 1520의 후속 모델입니다.
cd/dvd drive is missing from my system
Dell Inspiron 1525 does not see the cd/dvd drive. I can open the drive, but when closed, the drive light flashes several times and nothing happens.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 3개
What Operating System are you running on your Dell?
의
marsyoung, check your BIOS on startup. Make sure your drive is enabled.
의
thanks all - I had this problem - not found in bios either - I took the back off and I just reseated the drive. Perfect - all found
thanks again
의
댓글 달기
답변 5개
선택된 해법
Got it fixed - finally read a suggestion to check that dvd drive is seated firmly in the laptop - was slightly dislodged. Thanks to all for your advice!!!!
이 답변이 도움이 되었나요?
점수 3
댓글 달기
가장 유용한 답변
Power off, flip it over and remove/re-insert the drive. I've seen optical and hard drives across various brands and models where the drive will get slightly loose.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
change ur lens
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I'm not sure why you recommend changing the Lens. The fault stated is that the CD/DVD drive is not present and not that it is unable to read discs.
의
댓글 달기
Assuming that you are running Windows on your Dell, as this is a common problem, then there is a Microsoft FixIt application that usually resolves the missing DVD drive issue. Below is the link http://support.microsoft.com/mats/cd_dvd...
If this does not work then there is also a registry fix, removing the upper/lower filters. This can be done by following the directions below;
''Run Command Prompt (type CMD in the Start Menu on Vista/7)
Type in "regedit" without the parrenthesis then click ok
Go to HKEY_LOCAL_MACHINE
Then SYSTEM
Then CURRENT CONTROL SET
Then CONTROL
Then CLASS
Then find {4D36E965-E325-11CE-BFC1-08002BE10318}
The whole thing looks like this:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Then delete the upper and lower filters that appear on the right hand side.''
Hope this helps,
Wes
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Delete upper and lower filter from registry to retrieve your DVD drive from my computer.. Follow this link for more instructions.
http://www.techxure.com/2012/11/dvd-driv...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
marsyoung 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 15
전체 시간: 14,492
