์ฃผ์š” ์ฝ˜ํ…์ธ ๋กœ ๊ฑด๋„ˆ๋›ฐ๊ธฐ
์ˆ˜๋ฆฌ ์ปค๋ฎค๋‹ˆํ‹ฐ ๊ฐ€์ž… - ๊ณ„์ • ๋งŒ๋“ค๊ธฐ
2021๋…„์— ์ถœ์‹œ๋œ Dell Inspiron 16-7610 ๋…ธํŠธ๋ถ์— ๋Œ€ํ•œ ์ˆ˜๋ฆฌ ์ •๋ณด์ž…๋‹ˆ๋‹ค. Inspiron 16 Plus 7610์œผ๋กœ๋„ ์•Œ๋ ค์ ธ ์žˆ์Šต๋‹ˆ๋‹ค.
Possible to replace integrated webcam?
I suddenly started having issues with my internal webcam. All of a sudden it started being really blurry. I've tried cleaning the lens, but it does not work. I'm thinking perhaps a seal cracked and now moisture has gotten in there. Is it possible to replace just the internal webcam? Or do I need to replace entire screen to fix this?
์ด ์งˆ๋ฌธ์— ๋‹ตํ•˜๊ธฐ ์ €๋„ ๊ฐ™์€ ๋ฌธ์ œ๊ฐ€ ์žˆ์Šต๋‹ˆ๋‹ค
์ข‹์€ ์งˆ๋ฌธ์ž…๋‹ˆ๊นŒ?
์ ์ˆ˜ 0
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€ 1๊ฐœ
๊ฐ€์žฅ ์œ ์šฉํ•œ ๋‹ต๋ณ€
@zak18311 you did not give us your laptops model number but selected the Dell Inspiron 16-7610. You can download teh service manual for that computer from here Looks like that model has the camera integrated into the display assembly (the bezel around it actually). the camera is available as a spare part here for example. So that means you could try and use some heat to soften the glue that the screen into the assembly. Probably not an easy task and might be risking breaking the display, but nothing wrong with trying.
์ด ๋‹ต๋ณ€์ด ๋„์›€์ด ๋˜์—ˆ๋‚˜์š”?
์ ์ˆ˜ 1
๋Œ“๊ธ€ 1๊ฐœ:
Dell probably uses snaps on these, that's the best case though. If not, it's clips and (hopefully) weak adhesive.
์˜ ๊ณต์œ
๋Œ“๊ธ€ ๋‹ฌ๊ธฐ
๋‹ต๋ณ€์„ ์ถ”๊ฐ€ํ•˜์„ธ์š”
Zak ์˜์›ํžˆ ๊ฐ์‚ฌํ•  ๊ฒƒ์ž…๋‹ˆ๋‹ค.
์กฐํšŒ ํ†ต๊ณ„:
์ง€๋‚œ 24์‹œ๊ฐ„: 0
์ง€๋‚œ 7์ผ: 2
์ง€๋‚œ 30์ผ: 25
์ „์ฒด ์‹œ๊ฐ„: 901
