주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Yoga 920-13IKB는 화면을 뒤로 젖혀 노트북과 태블릿으로 모두 사용할 수 있는 투인원(two-in-one) 노트북입니다.
Computer Will not turn on or charge
Out of the blue, my laptop died. It won't charge. Charge light won't come on and it won't power up and turn on when the power button is pressed. I don't get it, as I hardly ever used this computer. I've heard the computer has some firmware issues reading online. But I tried all the recommended hard reset options, including detaching the battery cable. But no dice. Is my mother board dead? If so, how can I make sure? Thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
Hi @hatelenovoyoga,
Have you tried using a different, known working compatible charger to see if the laptop started to charge when it is connected, you didn't say?
Try using a strong light and a magnifying glass to visually inspect the USB-C charge port pin connectors (where the charger plugs in) to make sure that they're all there and not that some may be bent, broken or even missing.
Here's a link that describes the USB-C pin functions that may help.
If there are missing, bent pins etc then the charge port (supplier example only) will have to be replaced. You will need smd soldering skills and tools to do the repair. Here's the hardware maintenance manual that may also help as the systemboard will have to be removed so that the port can be replaced. The manual details how to do this.
If the charge port appears to be OK, here's a link to the schematic for the systemboard (if your model is an NM-B291 REV:1.0 that is). Go to p.41 to view the connections for the charge port so that you can check if power is getting through the port OK and how far into the board it gets etc.
Hopefully a start.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Here are some quick fixes for this issue
  1. Try changing your laptop charger
# If charging point is blinking and caps lock is blinking then you need to repair the motherboard of the laptop,
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
HateLenovoYoga 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 33
전체 시간: 1,125
