주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Game Boy Advance의 업그레이드 버전인 Advance SP는 2004년 3월 23일 북미에서 정사각형 구조와 클램셸 디자인으로 출시되었습니다.
Why is my screen so dim?
i remember the sp having a really bright backlight. i feel like mine might be dying. I checked my battery because it was draining so fast, i saw it had swollen up on one side, so i replaced the battery for a new aftermarket. It lasts longer than before, but the screen is still dim and I'm worried the previous battery's condition might have been a side effect rather than the true cause.
battery life on the original battery: about an hour maybe
battery life on the replacement: about 3 hours.
is my screen dying and causing my battery to drain faster?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
Usually all video devices that are rechargable have a screen brightness adjustment in the settings you maybe need to check and set it to a brighter setting.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
my gba sp only has a backlight on/off button. thats it, nothing else
댓글 달기
@charaznabl39130 "screen dying and causing my battery to drain faster?" most likely not. this sounds strictly like a bad back-light. You do want to remove the screen. Clean the connector with some isopropyl alcohol and cotton tip applicator. Check the ribbon cable for tears, corrosion or frayed ends. Check the button with a multimeter in ohm mode, to see if you have continuity when on and no continuity when off.
It also depends on how dark is dark. It is possible that the complete backlight has failed. Let us know the exact model number for your GBA SP and post some good pictures of your board, the ribbon cable and connector. That way we can see what you see. 기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Char Aznable 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 46
전체 시간: 2,526
