주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년에 출시된 자동 제빙기 기능과 컴팩트한 디자인을 갖춘 프렌치도어 스타일의 하단 냉동고형 냉장고인 Samsung RF20HFENB**에 대한 수리 및 추가 정보입니다. 이 페이지는 모델 번호 패턴이 RF20HFENB**인 모델에 대한 정보를 다룹니다.
Samsung model RF20HFENBBC
I have a water pooling problem under the fruit and vegetable drawers on both sides of refrigerator. I clean it up and it just returns. Can anyone help? Thanks in advance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi @patrick43472
Check if the drain tube (part #12 cabinet diagram) located in the drip tray below the evaporator unit which is behind a panel at the back of the refrigerator compartment is not blocked. (Access to the evaporator unit etc is through the door at the front by removing the panel at the back of the compartment).
This tube leads to an evaporator pan (part #14-2 cabinet diagram) located underneath the compartments.
When the refrigerator is in its defrost cycle, the meltwater from the defrosting accumulated ice build up on the evaporator unit, drips into a tray below the evaporator and then drains down to the evaporator pan and is evaporated naturally.
If it is blocked then the meltwater will back up and overflow into the refrigerator compartment.
There is also a similar drain tube below the evaporator unit inside the freezer compartment that does the same thing.
Try pouring a measured cup of water down the drain tube and check if all of it reaches the pan below the compartments.
Be safety aware disconnect the power to the refrigerator first
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Patrick 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 18
전체 시간: 451
