How to fix blue lines on screen
Hi. The screen has a few fading blue lines even when it is off. How do I fix this? It shows a little without light but a lot with light.
좋은 질문입니까?
좋은 질문입니까?
@anhadchugh just going by your description but this sounds very much like a bad display. BlackBerry 7280 LCD 스크린 및 스피커 교체 Post some pictures of what it shows, with your QUESTION. That way we can see what you see.
안내서
난이도:
조정
10 minutes
안내서
난이도:
매우 쉬움
2 - 5 minutes
이 답변이 도움이 되었나요?
Where can I find a replacement screen?
@anhadchugh that will be the biggest challenge. YOu can try and see if there are any numbers on the back of the LCD screen. If so, use those numbers for an online search. IF not then you have to try to use the BLackBerry 7280 LCD as a search string. You may even have to look at a 7280 that is broken other than the screen. Then harvest the screen from that.
지난 24시간: 0
지난 7일: 3
지난 30일: 11
전체 시간: 265
