주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 5월 22일에 출시되었습니다. 3,500mAh 용량의 배터리이며 모델 번호 SM-A415와 일치하는 EB-BA415ABY 식별 번호가 표시되어 있습니다.
Lens on back shattered
Can I replace the lens over the cameras and flash. It's shattered.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
If you are referring to the protective glass between the lens and the outside world, you certainly can.
Here is one vendor selling it: https://www.ebay.com/itm/304140055710
Or shop around to somewhere else. They can be bought in many places.
When replacing this glass, use a heat gun, iOpener, hair dryer, or other source of heat to loosen the adhesive. Carefully remove all glass shards, use a pair of tweezers to get any glass shards out from the cracks. Turn the phone over (NOT over your face! Over a trash can only!) and gently shake it for a couple minutes at all angles to give any small glass shards that may have fallen a chance to fall back out, and blow compressed air into it to help any stuck glass on it's way.
Remove any adhesive residue by peeling as much off with your tweezers as you can, and remove the rest with a q-tip dipped in 90%+ isopropyl alcohol. Use a clean, dry, nothing on it q-tip to remove any dust from the camera lenses carefully as the last step before putting the new protective glass on.
If your actual camera lenses have been damaged, your camera module(s) will need to be replaced to restore image quality. There is no way to fix a damaged lens without very delicate and technical repairs, and it honestly is not worth it versus the cost of replacing the camera.
Good luck!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
bill cassellius 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 10
전체 시간: 240
