주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz) 또는 2.5 (Turbo Boost 최대 3.7GHz) GHz 쿼드-코어 Intel Core i7 프로세서.
What’s the purpose of this metal plate covering the trackpad?
Does this metal plate serve to dissipate heat or something? Because the only thing on the other side of it is a battery, and I can’t see how it would short anything
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
The small screw attached to the plate is very difficult to remove!
댓글 달기
답변 1개
가장 유용한 답변
It’s important!
When correctly mounted it offers a bit more structure rigidity (case torsional twist) as well as offer structure for the battery. It also helps in controlling debris and liquid entry and lastly helps control the air flows as you don’t want air leakage to areas that don’t need cooling.
Please put it back!
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Took the words right out of my mouth.
댓글 달기
답변을 추가하세요
rickcostel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 95
