주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad T440p 비즈니스 컴퓨터는 2013년 11월에 출시되었습니다. 현재 Lenovo는 이 모델의 생산을 중단했습니다.
Laptop will turn off when moved.
So I’ve been having trouble with my laptop. When I even slightly move it the screen will go black, it won’t shut down but it takes some time to turn back on and when it does I have to sign in again. Sometimes I have to pick it up just for the screen to turn back on. I also constantly have a message saying “plugged in, not charging” so I am wondering if it has something to do with the battery?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@jhsworl you're not telling us if it does this on AC power as well as battery power. The "“plugged in, not charging”" could be a battery issue but could also be a issue with the charging circuitry on the board, Double check your DC in jack to ensure it does not have any loose connections.
Download the Hardware Maintenance Manual from here It will help you to work on your computer. If you get stuck or need further help, you can always post images of where you are or what you may have questions about, with your Question. Use this guide for that.
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jhsworl 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 7
전체 시간: 267
