주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 5월 출시, 모델 번호: SM-A217F/DS(글로벌), SM-A217F/DSN(러시아), 프로세서: Exynos 850, 3GB/4GB/6GB RAM, ROM: 32GB/64GB/128GB, 6.5인치 디스플레이, 15W 고속 충전을 지원하는 5,000mAh 배터리 및 USB Type-C 탑재.
Why Fingerprint is not work
why my phone Fingerprint is not working.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 3개:
My sensor fingertips stop working I don't know why
의 공유
@santosshishonge did you try the possible solutions listed in the above answer?
의 공유
did it previously work?
did you place a screen protector on it when it was working. Most tempered glass are not fingerprint compatible (too thick). The ceramic ones are, but I personally don't like any of them as they are to brittle and crack easily. The soft ones are best IMHO and they are compatible.
의 공유
댓글 달기
답변 1개
@yeabsirage73720 check in your settings to see if the fingerprint sensor still shows. Something like this video will show you how to set it up. If you can't, or if your sensor does no longer show in settings, then you will have to consider replacing the fingerprint reader. For the guides, check this site It does have the fingerprint reader guide listed.
While you work on your A21s, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Yeabsira Getachew 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 470
