주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 G15 모델은 최대 360Hz까지 지원하는 1080p 매트 디스플레이, 11세대 Intel i5부터 i7 11800H 프로세서, 11세대 UHD 그래픽, 그리고 GeForce RTX 그래픽 카드를 탑재하고 있습니다.
Why is my screen not working?
My screen for the laptop will not display, the keyboard will light up. I tried to do a LED test but it still wouldn’t turn on. I disconnected and reconnected the battery cable and it still doesn’t turn on!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi @zach48664
Troubleshooting steps.
  • Try getting into BIOS on startup (press F2 a few times very soon after starting the laptop) and check if there's a display showing. If you can't get into BIOS with a display is the laptop passing POST (Power On Self test) when starting?
If there is a display in BIOS then there may be a problem with the discrete Nvidia GPU. For the BIOS display the integrated Intel GPU is used.
  • Connect an external monitor (TV?) to the laptop's HDMI port and check if there a display on it when the laptop has be turned on and booted into the OS. Don't forget to press Fn +F8 (both together) to switch the display between the laptop screen only, the external screen only or both on together.
If there is a display on the external monitor, switch the display back to the laptop screen and then try shining a flashlight at an angle close to the laptop screen and check for any images. They will be very faint if they are there, so try this in a darkened room to help see them.
If you can see images, then there's a backlight problem with the screen. This could be either due to a faulty backlight power supply circuit on the motherboard, a faulty video cable or a problem in the screen itself.
If you can't see any images there may be a problem on the motherboard.
If there is no display on the external monitor there may be a problem on the motherboard or the laptop is not passing POST
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Zach 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 22
전체 시간: 1,705
