주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년에 Acer에서 출시한 Acer Nitro 5는 8GB RAM(적절한 하드웨어로 최대 32GB까지 확장 가능)과 빨간색 백라이트 키보드를 포함합니다.
Bezel and hinge broken- Need help replacing.
My laptop was dropped over a year ago and the bezel cracked. It's not been too much of an issue, but more recently the hinge has started to stick and at worst, has resulted in the bezel nearly separating from the screen. The crack in the bezel also means the thin piece of plastic on the side sometimes separates and altogether, the entire screen nearly falls apart if not held together with tape. (very temporary solution)
I will be clear in that I'm someone who knows next to nothing about tech repair, but I do have the help of someone who does, but hasn't done this exact thing before.
I have purchased replacement parts, but I cannot find a good and clear guide on how to replace the front bezel and hinge. Pictures of the damage below.
이미지
이미지
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
@samgeorge77840 iFixit does not yet have a guide for this. Try something like this video It is actually one of the better ones to follow.
While you work on your laptop, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sam George 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 14
지난 30일: 43
전체 시간: 986
