주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2021년에 출시된 LG의 보급형(21.5인치) 모니터입니다.
Vertical line started blinking every 7 seconds
Apologies for selecting the wrong LG monitor model.
The correct LG model is 20MP48AB (2017).
A few days back, a vertical line started blinking every 7 seconds, disappearing within 2 seconds.
Please help
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
I removed the D-SUB connection and switched on the monitor, but it still shows the same problem. Therefore, there is an issue with the display.
Has anyone had a similar complaint, and is it repairable?
댓글 달기
답변 1개
선택된 해법
@invisiblebond that looks like a failing source driver. That was apart of the ribbon cables from the LCD to the driver board (part of the LCD display).You could check that ribbon for corrosion, small tears and small burns in that flex. Depending on what you find, IT may need a new panel or just some additional pressure on the ribbon. Once you have it apart, take a couple of pictures and post those with your Question. Hopefully we can provide more insight.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Thank you for pointing out a workable solution. I hope the issue is related to the ribbon cable.
@invisiblebond I do too. I dislike having to replace anything just because of simple errors. Let us know what you find and how it works out.
댓글 달기
답변을 추가하세요
Invisible 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 33
전체 시간: 1,191
