주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mic problem in my phone.
Hello Sir,
Recently i got an issue in my one plus nord ce device as the person whom i am talking to cannot hear my voice in normal mode , I have to put my call on a speaker mode and then it is clearly audible to other person , what should i do .
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개:
Incoming sound problem
=== Update (10/23/23) ===
의
Touch screen problem
의
My problem
Mike problem
의
댓글 달기
답변 1개
Hi @divyanshrawat
Is the phone in a protective case at all?
If it is try removing it from the protective case and check if you can be heard OK when in normal mode.
If it isn't in a protective case or even if it was and you still can't be heard, use a vacuum cleaner to clear any dust, lint etc that may be blocking the small pin size voice inlet hole that is located on the bottom edge of the phone.
Do not use a pin or probe to try and clear the voice inlet hole as you may damage the microphone that is located directly behind it.
If it still doesn't work OK then there may be a problem with the microphone that is used for calls etc when in normal mode i.e. not in speaker mode as that uses a different microphone. The phone would have pt be opened and tested to find out what is wrong.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Divyansh Rawat 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 10
전체 시간: 838
