주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Monogram 냉장고에 대한 정보 및 수리 안내서
Freezer is getting too warm
I have a GE Monogram 42" Built in, model zisb42dyb. The freezer will get to -10 degrees and go all the way to 40 degrees. I have replaced the Defrost Timer and the Defrost Thermostat. I also replaced the Condenser Fan for a different issue. The issues continue.
I have realized that the evaporator fan does not operate consistently. It will operate properly sometimes and the freezer will drop to -10, other times it comes on and goes off within 2 seconds, not moving the cold air into the freezer compartment. I believe that is the issue. But, I don't know what controls the evaporator fan and sends a signal to turn on or off. Please help if you can.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hi @alexrivlin
If the refrigerator temp is OK but the freezer temp isn't, check that the dispenser door assembly is OK. (supplier example only to show part and has a video as well).
if it isn't closing properly it may be allowing warmer air to enter the freezer compartment thereby raising the temp.
If it is faulty and needs replacing, search online for WR17X11653 to find suppliers that suit you best.
Update (08/01/23)
@alexrivlin
Not sure if they're the same as a ZISB42 series but looking at the ZIS42 series service manual there is a delay thermostat associated with the evap fan, perhaps that is faulty. (see following page in manual I linked for location to check).
The parts suppliers I checked for your model don't mention it as a spare part, (they also don't mention it for the ZIS42 models either) only the defrost thermostat,
Perhaps it has markings on it that will help to find a replacement if it is faulty. Reading the description of operation and seeing an image of the thermostat it seems very similar to a bi-metal defrost thermostat in that usually they also operate at ~45°F to open the defrost heater circuit and close again at ~25°F to re enable the circuit after a defrost cycle has been completed to close the heater circuit again in readiness for the next defrost cycle.
You may even find that it is identical to the defrost thermostat in the freezer. If it is search online for WR50X45 to find suppliers that suit you best.
Here's a link that shows how to test bi-metal thermostats.
Seals the dispenser area in your refrigerator or refrigerator-freezer to prevent frost buildup. 이미지
제품
GE Dispenser Door Assembly - WR17X11653
$27.99
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thanks, The entire unit gets warm when the evap fan turns off at the times that it should stay on. I am not sure what controls the evap fan. Which is where I am stumped.
의
댓글 달기
답변을 추가하세요
Alex Rivlin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 41
전체 시간: 720
