주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Vankyo V7000(YG551) 프로젝터는 3,800 루멘의 밝기와 Full HD 1080p 해상도를 제공합니다. 2020년에 출시되었습니다.
How to open device?
How do I open the device? My cats knocked the projector off it's place holder and the focus doesn't work as it should. it seems like the lens was knocked out of its focus track and no longer spins unless I hold it for a long time. But it never gets the focus right. If I could get the body open, I could pop it back into place but I don't know where to start.
Thank you!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 3개
@jayeff
Looks like they redesigned as I don't have those screws at the bottom nor the pieces he pulls out in the beginning of the video :(
의 공유
How did you finally open it?? I have a similar issue with the lens, did you discovered what happen??
의 공유
I have my grandson's YG551 that his mother wanted to use as a classroom device but it wasn't working. These things are NOT made to be opened. There are some very deep screws that need a long very thin Phillips (I think) screws) which are virtually unreachable (and I have a LOT of different screwdrivers). Plastic push together pieces break when pulled apart. It doesn't take up a lot of room in the trash can.
의 공유
댓글 달기
답변 1개
선택된 해법
Hi @kennediehurt
Here's a video that may give you some clues as to how to open your projector.
I realize that is it not the same model, but mostly manufacturers don't alter things that much between models or if they do not often.
Worth a look perhaps anyway.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
@jayeff
의 공유
@kennediehurt
If the unit has rubber "feet" try removing them as sometimes there are screws underneath. Also check under any labels as they could also have recessed screws there.
Please unaccept my answer as it didn't fix your problem.
Cheers
의 공유
댓글 달기
답변을 추가하세요
Kennedie Hurt 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 44
전체 시간: 1,018
