주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PSP E1000은 Sony에서 설계한 휴대용 게임기입니다. PSP Street로도 알려진 이 보급형 PlayStation Portable은 2011년 10월에 출시되었습니다.
PSP E1004 White Screen
I just replaced my PSP E1004 motherboard because I had a whitescreen, and I thought it might be due to solder joint issues on the CPU. So, I ordered a new motherboard from Aliexpress and replaced it. However, I am still facing the same problem.
Does this mean that my replacement motherboard has the same issue as my old one, or could something else be broken?
이미지
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@vistalu motherboards from two separate places with the same error, is possible but unlikely. The white screen is just your backlight turning on and really does not give you an overall idea about the display. I'd check the ribbon cable. check for tears and nicks etc. OF course, you have checked this guide How to fix the PSP E1000 psp e1000 WHITE SCREEN - iFixit Repair Guide as well. If none of this works, try a new display as well.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I already checked the ribbon cable, and I didn't see any tears. It looked normal to me.
I even checked if I connected the ribbon cable correctly to the connector multiple times, and still, nothing worked.
When I turn on the display, I can see outlines of the PSP menu when I hold my PSP at a specific angle and look at it.
의
@vistalu this " outlines of the PSP menu when I hold my PSP at a specific angle" could be a video IC issue. Your boards may actually need a reflow of that IC. Unless the polarizer of your screen are having issues. DO you have any polarized sun glasses? If so places those over the display and slightly rotate them in 90deg increments. If you can at anytime see more of the screen, it is the polarizer films and you would need a new screen.
의
댓글 달기
답변을 추가하세요
Lukas Pelka 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 13
지난 30일: 51
전체 시간: 1,914
