주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2022년형 풀사이즈 냉장고 모델인 Frigidaire 냉장고 FRSS2623A*에 대한 수리 정보와 추가 안내. 이 모델은 빌트인이나 도어 관통형 기능은 없으나 자동 제상 기능을 갖추고 있습니다. 이 페이지는 FRSS2623A* 패턴과 일치하는 모델 번호에 대한 정보를 다룹니다.
Frigidaire Freezer Not Dropping Ice
Hi all,
I have a side by side Frigidaire freezer/fridge, model number FRSS2623AS6.
Water will enter the cube tray fine and freeze, but will not drop. When I cycle the control panel on and off (green button), the tray begins to rotate, but the feeler arm doesn’t go all the way down. If I manually push it down gently, it will go down and drop ice, then fill back with water.
I attempted defrosting for a little while, but that did not work. I haven’t taken it apart to see if maybe something is stuck or out of alignment with the feeler arm and motor inside. I’ve also attempted a reset, which also did not work.
I’ve attached a picture, and video at the best angles I could get with the bin still installed.
Any suggestions or thoughts?
Thanks so much!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
First thing I would do is to pull it out and let it completely defrost:
https://www.subzero-wolf.com/assistance/...
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Ok will try that in a few and see. Thanks.
의
That was it.
I haven’t fully reinstalled, just plugged the harness back in to check if the feeler arm goes down on its own, and it did, once for drop, again for water recharge.
Going to let it sit out and fully evaporate any remaining liquid so it doesn’t refreeze after reinstall.
Thanks!
의
댓글 달기
Hi @nicklemay
If it still doesn't work OK after you reinstall it, here's the service data sheet for the model series, that may help.
It describes how to manually run a test cycle on the ice maker.
If there is a fault and a replacement part is required, here's a parts list that may be useful.
Scroll across to the ice maker parts diagram to find the part and then the part number for the part. Then search online using the part number only to find suppliers that suit you best.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
This is also very useful, thank you.
의
댓글 달기
답변을 추가하세요
Nick LeMay 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 41
전체 시간: 2,635
