주요 콘텐츠로 건너뛰기
The 8th generation Honda Accord
20 질문 전체 보기
AC compressor clutch not engaging
It has enough freon, but wont engage. Not sure how to fix or even troubleshoot
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Hi @augustavan81723
Check if the 7.5A fuse # 20 (marked as MG clutch - magnetic clutch) in the engine bay fuse block is OK.
Magnetic clutch is the term used for the AC compressor clutch, presumably because it is electrically operated
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Fuse 20 does not appear to be blown or corroded
댓글 달기
@augustavan81723 since you checked the fuse you know that it at least should have power. I suggest that you next use the self diagnostic function for your HVAC. Here is how to do that.
Automotive AC are pretty complex so it will be difficult to go through each step on here. Use the HVAC part of the SM for your checks and let us know what you find out and where/if you get stuck. Honda Accord HVAC
After the self diagnostics, my next step would be check the clutch itself. if the tests all came back looking good.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
You'll also want to check the relay, if the fuse is good. Sometimes the high/low-pressure switch could be bad, causing the compressor not to engage.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
August A Vanden Top 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 36
지난 30일: 87
전체 시간: 2,378
