주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
AC compressor clutch not engaging
It has enough freon, but wont engage. Not sure how to fix or even troubleshoot
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개
@oldturkey03, would you have the Honda Accord HVAC troubleshooting manual for a 2012 Honda Accord SE?
Thank you, Bigfish.
@bigfishtanner I just checked and the latest Accord manual I have is for the 2010
Thank you @oldturkey03! The self-diagnostic procedure showed an open evaporator temperature sensor circuit. I was taking the sensor out and found the last person bent one of the two pins over in the connector.
I checked the 7.5 fuse and the compressor relay both checked out good but when I checked the high pressure a/c port I got a mini screw driver and tap the port no freon fizzed out, Could this be my problem as to why the a/c clutch isn't engaging??
댓글 달기
답변 3개
가장 유용한 답변
Hi @augustavan81723
Check if the 7.5A fuse # 20 (marked as MG clutch - magnetic clutch) in the engine bay fuse block is OK.
Magnetic clutch is the term used for the AC compressor clutch, presumably because it is electrically operated
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Fuse 20 does not appear to be blown or corroded
댓글 달기
@augustavan81723 since you checked the fuse you know that it at least should have power. I suggest that you next use the self diagnostic function for your HVAC. Here is how to do that.
이미지
이미지
Automotive AC are pretty complex so it will be difficult to go through each step on here. Use the HVAC part of the SM for your checks and let us know what you find out and where/if you get stuck. Honda Accord HVAC
After the self diagnostics, my next step would be check the clutch itself. if the tests all came back looking good.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
You'll also want to check the relay, if the fuse is good. Sometimes the high/low-pressure switch could be bad, causing the compressor not to engage.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
August A Vanden Top 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 42
지난 30일: 262
전체 시간: 6,868
