주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech M185 컴팩트 무선 마우스의 수리 안내서, 분해 정보 및 문제 해결입니다. 부품 번호(P/N) 910-002225로 식별됩니다.
My Logitech M185 does not turn on
Hi, I just got a used Logitech M185 but it does not turn on.
I already opened it but I couldn't find anything suspicious.
Is there anything else I could try?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 6개
Have you tried changing batteries?
의
Yes, I already tried that.
의
@websnke When you turn on the mouse then plug the USB receiver into your PC, is there a sound from your PC speaker?
의
@dannish
The main problem is that the mouse doesn't turn on at all. The USB receiver should be fine.
의
@websnke These sort of mice use an invisible optic system so you can't visually tell if the mice is running or not, they don't have the usual red laser of most mice. Hence the need for the sound to really check if the mouse is active and being detected.
의
댓글 1개 더보기
댓글 달기
답변 1개
선택된 해법
Hi @websnke
Are the battery connector terminals in the mouse, bright and shiny i.e. not corroded and are they exerting enough tension on the battery when it is inserted, ensuring a good electrical connection?
If so then you may have to open the mouse and check for any obvious problems on the motherboard e.g. loose solder joint on motherboard from the battery terminals or water damage to the board, burnt looking components etc.
Being a "used" device, unless you know its history, you don't know what may have happened to it.
Here's the ifixit Logitech M185 무선 마우스 분해 guide that may help.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
how do you get an answer?
의
@mauricelew63161
To get an answer, first you have to ask a question
Here's some information that may help.
How to ask a question
iFixit에서 좋은 질문을 하는 방법
Moderator
의
댓글 달기
답변을 추가하세요
[deleted] 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 30
전체 시간: 2,113
