주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The XIAOMI Mi L32M6-EI TV, also known as the Mi TV 4A Horizon Edition (32-inch), is a HD Ready (1366 x 768) Smart Android LED TV launched in 2020. It runs on Android TV with built-in Chromecast and Google Assistant.
My TV Does not Start
Hey Team,
My MI 4A TV is neither starting from the remote nor from the power button of the TV. The red light always keeps on burning in the TV, which used to turn off after starting the TV, but now it does not turn off.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 9개:
Foxsky led tv 32 inch pawer on problem
No my tv was after starting it white screen coming
My tv does not start
Tv not open
Read light show but tv not on
@henockberhane are you looking for something?
댓글 4개 더보기
댓글 달기
답변 2개
@devsharma59131 that is a little known TV and of course schematics etc. are not available. WE would need to see your boards. Remove the back cover from your TV and take a look at all the boards. Check for obviously damaged components. Like blackened,charred or missing components. Post some good pictures of each board as well as one of the complete layout, so we can see what you see.
Since the red power LED light is on, that would mean your power board supplies the standby voltage. It could be an issue with the main board not "telling" the power board to turn on. For that you would have to measure the voltages on the connector from the power board to the main board cable.
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Any TV with a remote has the internal remote control circuit powered all the time (red LED indicator on). When triggered, it closes a relay or solid state switch that is usually on the power board (red LED off). The power switch will trigger that as well as a signal from the remote. Therefore the likely cause would be the power board, but may be the remote receiver which is normally separate.
At any rate, it requires opening up the TV and making some tests. But, without service info it will amount to parts jockeying to find the right part - and it may be just a bad connection.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dev Sharma 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 81
전체 시간: 1,555
