주요 콘텐츠로 건너뛰기
Model number DSC-2100. Sony 12.1 mega-pixel point-and-shoot camera
Why is camera not turn ON
Camera not turning on
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개
Hi @priyeshcamera,
Have you tried using new fresh batteries in the camera to see if it turned on, you didn't say?
Yes, I already checked it
Start problem not running
Camera is 1year old please recover
댓글 달기
답변 1개
가장 유용한 답변
@priyeshcamera if you are sure you have a good battery and if your battery case door functions properly, time to take it apart. Use this guide Sony Cyber-shot DSC-S2100 LCD Replacement to get into your camera. Once there, you need to check the motherboard. Make sure that the battery cables are properly attached and then check the fuse for continuity. One is the power fuse.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Priyeshcamera 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 48
전체 시간: 577
