주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 9월 14일에 출시된 Realme의 중급형 스마트폰입니다. Snapdragon 720G 프로세서, 최대 8 GB RAM, 128 GB 내장 스토리지를 탑재했으며, 6.4인치 Super AMOLED 디스플레이를 갖추고 있습니다.
Power bottom not working
Pawer bottom not working
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 11
댓글 7개
Change display change
의 공유
@syedrehan44267 why would you change the display if the power button isn't working?
의 공유
Pavar batan Working not
의 공유
Power button not working
의 공유
Phone power button is demage
의 공유
댓글 2개 더보기
댓글 달기
답변 6개
가장 유용한 답변
. Open the back door first (pasting by gum)
. Unscrew all
. Open the backcase carefully
. Remove all connected strips
. Remove the mother board
. Remove the power strip.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
@kingashis you are not giving us a lot of information. All you could do is give us 4 words to try and help you? It would be nice to know what you have tried to fix this. Or at least to let us know what you have checked.
First off you want to reboot your phone to eliminate any temporary glitches. Press and hold the volume down button and the power button simultaneously for about 10-15 seconds
After that you need to make sure that you have the latest update for your firmware. Check on that by going to Settings > About Device > Software Updates > Check for Updates.
Next clear the cache by going to To clear storage cache, proceed to ******Settings > Storage > Cache Storage
Now if none of that work(ed)s you may have to replace the power button flex. For that use this guide
Replacements are available at plenty of online stores. Just do a search and select a vendor that appeals to you.
Since iFixit does not yet have a guide, it would be great if you could help out. While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Well I will suggest you to check out the following video: https://www.youtube.com/watch?v=1TnPiP_0...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Yes phone power botten not good work
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Update (11/12/25)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Power button not working phone off on
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
king Ashis 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 31
전체 시간: 2,936
