주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 기기는 모델 번호 7420으로 식별되는 Dell Latitude 장치입니다. 탄소 섬유 케이스, 터치 스크린, 기기 잠금 해제를 위한 지문 인식기가 특징입니다.
Where is the CMOS Battery?
Where is the CMOS Battery located on the Dell Latitude 7420?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
Cmos battery is inbuilt with battery.
의
Where do battery smos
의
댓글 달기
답변 1개
가장 유용한 답변
Hi @splitintwain
There is no separate cmos battery connected to the motherboard in a Dell 7420.
The RTC (Real Time Clock aka cmos) battery supply is provided by the main battery.
Here is the service manual for the laptop.
Go to p.27 (or p.30 depending on battery type installed), to view the procedure to remove the main battery.
Take note that it mentions that by disconnecting the battery that the laptop is RTC reset i.e. the BIOS settings will be reset to the default factory settings.
If you wish to reset the BIOS and restore any possibly corrupted settings by removing the battery you simply have to disconnect the battery cable from the motherboard and not remove the battery itself.
It may also be prudent that once the battery cable has been disconnected to press and hold the laptop's power button for 15 seconds, to ensure that all the residual power stored on the motherboard has been drained as well, before reconnecting the battery cable to the motherboard.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thank you, @jayeff, that is very helpful! And it also explains why I could not find the battery after a complete disassembly of the laptop. I appreciate the quick response!
의
댓글 달기
답변을 추가하세요
splitintwain 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 9
지난 7일: 37
지난 30일: 173
전체 시간: 9,026
