PUSH Protect error message
I have BDV-N580 bluray player when turned on I'm getting a display message as PUSH PROTECT and the display is not changing to other menu options when operated manually or through the remote.
좋은 질문입니까?
좋은 질문입니까?
@subramanin sounds like your BR player has gone into power protect mode. When that happens you pretty much cannot access anything on your player until the error is cleared. Try a rest first. For a reset remove everything that is plugged in to it and let it sit for an hour or so. Now, I am not familiar with your model so I can not tell you if there is a reset button. Some Sony's have a reset button or a reset hole (insert a paperclip into that and hold for 15-30 sec to reset).
ALways make sure that everything plugged in makes proper connection and check your power cord etc. If a reset does not work and it continues to display the message, it may be time to disassemble it and check the power supply etc.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 6
지난 30일: 26
전체 시간: 339
