주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Western Digital에서 출시한 250GB 3.5인치 SATA 하드 드라이브입니다.
Hdd is not getting detected
When i turn on the pc harddisk turns on and then turns off after 10-15 seconds. I want to recover my data from that disk. I tried to contact manufacturers of that disk but they say that disk is a copy and not a genuine one. I also tried to connect that drive to other pc but there also not getting detected
What should i do ?
That data is very much important to me. Please help
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 1개
I have already recovered some HD's by removing the electronic board and resoldering it with the hot air rework station.
댓글 달기
답변 2개
가장 유용한 답변
@khushaldhumane explain to us what this means "they say that disk is a copy". There are two possible failures, The controller board or the mechanical part. If it is mechanical, you want to leave your hands off and send your drive for data recovery to a place that specialize in this. Those are not cheap.
For the controller issue, you could try to replace the controller board. I've done that a few times and successfully removed data from those drives. But, you will need to get the right board etc. Not always an easy find. Check this guide for what I am referring too,
Hitachi GST Deskstar HDS721010CLA332 하드 드라이브 컨트롤러 교체
If you need more info or guidance, post some good pictures of your board etc. with your Question. that way we can see what you see.
기존 질문에 이미지 추가하기
iFixit 이미지
안내서
기존 질문에 이미지 추가하기
난이도:
매우 쉬움
2 - 5 minutes
Hitachi GST Deskstar HDS721010CLA332 Hard Drive 컨트롤러 이미지
안내서
난이도:
조정
20 minutes
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I am also stuck in the almost same situation. In this case, put your HDD in the sun for around 1 hour, then let it cool down for 10 minutes, and then insert it. In some cases, the HDD is fully recovered, and in some cases, it shows up in your PC for around 5-6 hours or a day. I recovered my data with this method.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Khushal Dhumane 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 142
전체 시간: 3,808
