주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Phone internal memory full
What should be the solution
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
Saya juga mengalami ponsel perangkat penuh
의 공유
댓글 달기
답변 3개
가장 유용한 답변
Hi @adewuyiadebayo
To increase the storage in the phone insert a micro SD card (up to 512GB capacity) into the phone and then move your apps/personal data etc from the internal storage to the SD card.
Here's an image that shows how to insert/remove and format the SD card that may help.
이미지
(click on image)
Here's the user manual for the phone that may also help.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
My first suggestion is to delete any apps that you don't use. If that doesn't lower it, then go to your settings and navigate to battery and device care. Once inside, click on storage it will show you a breakdown of what is taking up most of your storage. Now, the next thing to do is start cleaning out your storage by going to each problem spot and start deleting any unnecessary files and/or apps. Hopes this helps!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Clear unwanted and old files every 6month please do software reset
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ADEWUYI ADEBAYO 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 24
전체 시간: 907
