주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2021년에 발표된 Bullitt Group 제조의 안드로이드 폴더폰입니다. Caterpillar Inc. 브랜드 라이선스를 받아 CAT 폰 시리즈로 생산되었습니다. CAT S22라고도 불립니다.
Pogo connection positive / negative side
I want to 3D print a charging cradle for my CAT S22 FLIP phone. I can't seem to find any information online as to which side of the pogo connection is positive and which side is negative. If anyone out there knows the answer, please let me know. Thank you in advance.
P. S. If you need photos of the phone and the cable that I plan to use, let me know and I will send them. Thank you.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 4개
Will you be posting the result anywhere when you are finished? I am also wanting to print a charging dock and would love to see what you come up with
Yes I will be posting an update. I'm currently waiting for the charging cable to arrive. And a friend is going to let me borrow his multimeter so that I can figure out which side is positive / negative. I still can't believe that CAT never made a drop in charger!! Why have the connections there if you're NOT going to offer a charging cradle?? And their online "chat" feature... They REFUSE to answer the question on which side is positive / negative!! So much for their "customer service"!!!!!
Hi Scott
Did you contact "bullet", the producer of the CAT phones?
Any way I would like to own 2 or 3 cradels too. Can't print my self though...
If you had former information that might help me, please let me know.
I 'm on the mail list since today
Best Albertjan
albdijk@gmail.com
I want to do the same- did you find or make a 3D file- if so, can I get a copy? Thank you,Ken it045@yahoo.com
댓글 달기
답변 2개
가장 유용한 답변
Hello! Bit of a long shot, but I wonder if those contacts will be tied directly to the normal charger connections, you could try to measure them with a multimeter while the phone is on charge! @scottantho50551
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Looking at the phone from the rear, with the pogo pins at the bottom, the positive terminal is on the left. Connect your charger positive to positive, negative to negative. The pins are 8mm apart.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Confirmed, + on left/ - on right and measured (while charging) voltage 5.2V DC So it's probably directly connected to the side USB (C) plug on the phone. Best on your project. Dr. Bob ;-)
댓글 달기
답변을 추가하세요
Scott Anthony 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 31
전체 시간: 2,139
