주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mobile not vibrating software problem
Vibrate motor is ok bit. Mobile not
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
@harmansand19435 so the only problem is that the vibrate does not work? Everything else does? How did you check the vibrate motor?
의 공유
댓글 달기
답변 1개
Hi @harmansand19435
Here's an image the vibrate motor trouble shooting flowchart from the service manual that may help.
There's also an image, one zoomed in and one normal size of the board layout showing where the components mentioned in the flowchart are located.
It the troubleshooting tests prove that the hardware is OK, then you may have to reset the phone back to default using a factory restore to see if it is a software problem. Note: Be aware that doing this will erase all your personal data and downloaded apps, so backup the phone to the cloud or a computer before you do the restore.
이미지
이미지
(click on image)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Harman Sandhu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 5
지난 30일: 15
전체 시간: 280
