주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2018년 5월에 출시된 삼성 갤럭시 A6 플러스(Samsung Galaxy A6 Plus)는 갤럭시 A6의 플러스 모델로, 화면 크기를 5.6인치에서 6.0인치로, 카메라 화소를 1,600만 화소에서 2,400만 화소로 업그레이드했습니다.
The charging jack problem
The charging jack of my phone is damaged and the charging keeps shaking when I plug in the charging cable.The charging jack of my phone is damaged, it keeps shaking when the charging cable is connected, how can it be fixed, please help me.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
Rohit, unfortunately your charging jack is mounted directly on the motherboard so unlike other Samsung models, there isn't a separate part that can be replaced to fix the charging port.
I'm afraid you're going to have to find someone experienced in microsoldering who can remove and replace that tiny port from your motherboard. I consider myself fairly talented at soldering but I would hesitate to attempt this one on my own; if you're not really good at it I wouldn't recommend trying to fix it yourself.
The closest I can come to offering you help is this guide showing you how to remove the motherboard so you can get to the charging jack, but after that I'm afraid you're on your own.
Manuales / Samsung Galaxy A6+ / Motherboard
Otherwise the only thing you could do would be to replace the entire motherboard, which is basically going to be the same as replacing the whole phone.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Hi @rohitsaxen93718,
Here's the part number for the charge port connector - 3722-003954
Search online using the part number to find suppliers that suit you best
의
댓글 달기
답변을 추가하세요
Rohit Saxena 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 30
전체 시간: 746
