주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
시장 상황에 따라 Echo, Yaris 또는 Platz라고도 불리는 소형 Toyota 세단 모델입니다. Echo/Yaris의 해치백 버전은 Toyota Vitz로 알려져 있습니다.
Change the radiator water
كيف يمكنني تصفية ماء الرديتر واعادة التعبئة
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@nawaf55330 from the service manual:
이미지
DRAIN ENGINE COOLANT
  • a. Remove the radiator cap.
CAUTION:  To avoid the danger of being burned, do not remove the radiator cap while the engine and radiator are still hot, as fluid and steam can be blown out under pressure.
  • b. Loosen the radiator drain plug (on the right side of the radiator lower tank) and engine drain plug on the engine coolant drain union (on the right front of the cylinder block), and drain the coolant.
  • c. Close the drain plugs.
  • Torque: 13 Nm (130 kgf-cm, 9 ft. lbs.) for engine
2. FILL ENGINE COOLANT
  • a. Slowly fill the system with coolant.
    • Use of improper coolants may damage the engine cooling system.
    • Use "Toyota Long Life Coolant" or equivalent and mix it with plain water according to the manufacture directions.
    • Use of the coolant which includes more than 50% [freezing protection down to -35°C (-31° F)] or 60% [freezing protection down to -50°C (-58°F)] of ethylene-glycol is recommended, but not more than 70%.
NOTICE:
Do not use an alcohol type coolant or plain water alone.
The coolant should be mixed with plain water (preferably demineralized water or distilled water)
Capacity of the coolant for Manual Transmission is 4.4 US qts. (4.2L) and 4.3 US quarts (4L) for the Automatic Transmission vehicles
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nawaf 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 34
전체 시간: 1,310
