주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Laptop 14-dk1022wm은 작고 가성비가 뛰어나 학생과 일반 직장인이 학교, 업무, 개인용으로 널리 사용하는 기기입니다.
Its hinge is broken and cracking.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
Hello, I’m sorry to hear that your HP Laptop 14-dk1022wm has a broken and cracking hinge. This is a common problem that affects many laptops over time. There are a few possible causes and solutions for this issue:
  • The hinge may be loose or misaligned due to wear and tear or physical damage. You can try to tighten the hinge screws by following the instructions on this guide. Make sure you have the right tools and skills to do this, or seek professional help if you are not confident.
  • The hinge may be broken or cracked due to excessive force or impact. You can try to replace the hinge by following the instructions on this video. Make sure you have the right replacement part and tools to do this, or seek professional help if you are not confident.
  • The hinge cover may be broken or cracked due to cosmetic damage or aging. You can try to replace the hinge cover by following the instructions on this article. Make sure you have the right replacement part and tools to do this, or seek professional help if you are not confident.
You can find more information about your laptop’s parts and components on this page. You can also find more setup and user guides for your laptop on this page.
I hope this helps you with your HP Laptop 14-dk1022wm hinge issue. 😊
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
@kingofspades you need to check your AI's links. "by following the instructions on this guide " There is no guide. It links to the HP Customer Support site.
의
@oldturkey03 I see! thank you for pointing out my mistakes!
의
댓글 달기
@donaldcrump besides all the technobabble from the AI in the preceding answer, all you have to do is to download the service manual for your computer from here The hinges are listed as part of the display assembly. Page 64 will tell you how to work on those as well as giving you the part number for the replacements etc. If the hinges are too broken, they may even have cracked the top case, so you may need to replace that as well. Sometimes it helps to post images of the damage. That way we can see what you see and hopefully guide you further.
기존 질문에 이미지 추가하기
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Donald Crump 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 19
전체 시간: 431
