주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2002년에 출시된 Windows XP 운영 체제를 사용하는 데스크톱 컴퓨터, Dell Dimension 2300의 수리 안내서 및 문제해결 정보입니다.
VGA single not shown on led
No single is find or come from ur pc
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
@gurmeetsin55517 Let us know if you are you using a dedicated video card or the one that is integrated to the motherboard. Let us know what you have check. you definitely need to check another monitor to see if this is a monitor issue. You can of course also try the monitor on a different computer to make sure it is working. If you are using a dedicated video card, you may need to remove it and clean the contacts with a pencil eraser. Just use it lightly, no reason to do it forcefully. After that reseat it. If you are using an integrated video, I would try and get a dedicated card. See what that shows.
Download the service manual for your Computer [https://dl.dell.com/manuals/all-products... |from here} It will help you to work on it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
gurmeet singh 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 364
