주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2004년 9월 Sony에서 출시한 더 작고, 얇고, 조용한 PlayStation 2(SCPH-700xx) 모델입니다.
What capacitor is this?
This is a photo of another board but on the board i am working on, the capacitor is leaking and needs to be changed. I am not sure what the capacitor is, does someone know what capacitor it is?
이미지
이미지
이미지
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
@choukosenpai you do want to go ahead and post a larger picture so we can at least try to help you with to much eye strain :-)
What board number is this?
it is a SPCH- 77004 board, i would post a clearer photo of the component though the leakage of the component has removed the text ontop of the component. hopefully it helps
@oldturkey03 this is the closes schematic that i have found
https://gamesx.com/wiki/lib/exe/fetch.ph...
댓글 달기
답변 1개
선택된 해법
@choukosenpai does not look like a capacitor at all. That looks like a coil. If you can post a bigger picture so we can see whatever it is that is printed on it, I am sure we can identify this component.
Update (10/03/23)
Thank you for adding the image to your Question. Like I suspected it is a coil. In this case it is a 3.3uH inductor. Now the only thing you have left is to measure the physical dimensions (width and length) This will be an easy part to source. Fairly straight forward repair too. What Country are you in (no details please) so we can try and find a supplier.
이 답변이 도움이 되었나요?
점수 1
댓글 10개:
i have added a new picture, the thing is that i cant get a close up of the component since the leakage of the component has removed the text ontop of it, that is why i said that it is another photo of the board (i have taken this photo from google)
@choukosenpai Ok let me look at this in a few hours. I am at a place right now that does not allow me to look at it. :-)
@oldturkey03 alright thank you,
@choukosenpai it's identified :-)
댓글 5개 더보기
댓글 달기
답변을 추가하세요
Mr_Chou 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 29
전체 시간: 779
