주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
삼성 갤럭시 A22 5G는 갤럭시 A 시리즈의 일부로 삼성전자에서 개발 및 제조한 중급 안드로이드 기반 스마트폰입니다. 이 휴대폰은 2021년 6월 24일에 처음 출시되었습니다. 이 전화기에는 트리플 후면 카메라 설정과 90 Hz 디스플레이가 함께 제공됩니다. 배터리는 5000 mAh로 iPhone 13 Pro의 배터리보다 62% 더 큽니다.
Why does my volume button does work?
I been having these difficulties in past 3 months that my up and down volume doesn't work any more?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi @juanmigueldoton,
Has the phone been dropped or gotten wet at all?
의 공유
Yes it's I've been drop it many times but It didn't get wet
의 공유
댓글 달기
답변 1개
선택된 해법
Hi @juanmigueldoton
Dropping a phone certainly doesn't so it much good.
It may be that the volume problem is caused by a loose or faulty power and volume flex cable (part # GH81-20712A) or perhaps a faulty power/volume control button (supplier example only to show the button)
With regards to the other problem you're having with the headphone jack, it could be a faulty headphone jack. There's an internal spring that signals the audio control when a plug has been inserted into the jack so perhaps its intermittently operating when it shouldn't be. If this is the case then the jack would have to be replaced as it cannot be repaired. The good thing about this is that the jack is on the charge port board which is a separate module so it's easy to replace once the phone is open. The part number for the charge port board is GH81-20699A.
To find suppliers for the parts search online using the part number only. Couldn't find a part number for the control button so if it is faulty search for Galaxy A22 5G power/volume control button.
Here's a teardown video for the phone which may help.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
JuanMiguel Doton 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 16
전체 시간: 324
