주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Powerbeats Pro 완전 무선 이어버드에 대한 수리 및 분해 정보입니다. 2019년 5월에 출시되었습니다. 모델 번호: MV6Y2LL/A, MV702LL/A, A2047.
How do I replace worn out batteries
The powerbeats pro charge to 100% in the case and shut off after 30 minutes of use
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 5개
I ordered a pair of Varta CP1254 A3 batteries advertised for Powerbeats on eBay but the 5.4mm height is about 1mm taller than the OEM battery. It doesn't fit. All the listing specs also have 5.4mm height? Any suggestions?
의
@bloodygalah
Have you checked the original battery to see what model number is stamped on it?
의
@jayeff
No markings on the OEM battery at all I'm afraid
의
@bloodygalah
That makes it tough.
You may have to measure the dimensions and then see if you can find a similar size "3.7V 0.2W rechargeable battery with solder tabs".
Soldering wires to a battery is dangerous as it heats the battery too much. That's why getting batteries that already have them factory fitted is better and safer
의
@bloodygalah
Apologies, must have had a brain fade.
Obviously not AA size.
Also since the original has no markings make sure that if you do find a replacement that you connect it correctly i.e. +ve side of battery to +ve wire from the board if wires are coloured then red wire is +ve and black wire is -ve.
You may need to have a DMM (digital multimeter) to find out which is the +ve side on the original battery if the connecting wires aren't coloured differently.
의
댓글 달기
답변 1개
가장 유용한 답변
Hi @harveyhimel
Here's the ifixit Powerbeats Pro 분해도 video that shows how to access the battery.
The battery make and model number is Varta CP1254 A3. Search online for Varta CP1254 A3 to find suppliers that suit you best.
Here's an image from the video that may help
이미지
(click to enlarge)
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Harvey Himel 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 40
지난 30일: 187
전체 시간: 15,462
