WF7708N6W1 not draining
Hey all,
I have a Samsung WF7708N6W1 that isnt draining - i have removed the drain filter and removed all the crap, but still getting the SE / 5E error.
Turning the machine on its side i was able to access the Pump and filter ASSY. Removing the hoses i found a lot of loose change on the inlet side to the pump which i have removed. I have also removed the waste hose and checked for blockages, none found.
To me it seems pretty concrete the pump is failing, however i thought i would check in with the brains trust to make sure im not about to spend up to $80 AUD + shipping for a replacement pump.
It seems the original pump is NLA however i can get a suitable repalcement here:
Replacement Pump
TIA
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Updated the URL to the replacement pump
댓글 달기
