Disk read error occurred
My laptop has ran into a error where the disk can't be read, I pressed f2 and I don't know how to reset/reboot it, non of the "Boot priority orders". Help me please
์ข์ ์ง๋ฌธ์ ๋๊น?
์ข์ ์ง๋ฌธ์ ๋๊น?
First of all - can you see the hard drive in the BIOS? If 'yes' then try the Windows recovery environment:
If your device isn't loading or stuck during boot, you can use this method to access the recovery environment:
After the third interruption, Windows 10 will open into the Advanced Start-up environment
ยทย ย ย ย ย ย ย ย While in the Advanced start-up environment, use the following steps to use Start-up Repair:
You could also try running 'chkdsk' command look in advanced options
From CMD Prompt
ย Run following:
ย Chkdsk /F
If that doesn't work you may need to run a drive sector recovery software.
์ด ๋ต๋ณ์ด ๋์์ด ๋์๋์?
์ง๋ 24์๊ฐ: 0
์ง๋ 7์ผ: 6
์ง๋ 30์ผ: 35
์ ์ฒด ์๊ฐ: 379
